To remove fuel cut on the emanage you need to use the emanage software and cable and open up the boost limiter setting and set the voltage to 4.10volts, that should work for you but please be aware you should have a wideband installed while playing around with boost settings even more so when going above stock fuel cut!
Many Thanks
~Nick @ Tuning Developments
