Chris_GlanzaV98
After fitting a new head gasket i then fired the car up and it started after a few cranks, ideling at 2k revs i assume this is because it has been in bits an when it heats up should calm down. I didnt have the chance to let it head up as power steering fluid started gushing out from like behind the pump and running over the oil filter and down to the ground, have no idea why it is doing this because it was fine when i took it off , really gutted to be honest
Any ideas what it could be ? I checked the big screw to make sure it was lined up with the holes inside the pipe, could it be the double washer ? The pump itself ? Or maby even the pulley ?
Cheers for the help !
