E10-2001-CT9
hi, got my 4efte rebuild (wössner pistons), block and head skimmed. so my pistons are 0.10mm higher than the block. I want to use 0.6mm TRD head gasket because want better response with OEM CT9. I would only have 0.5mm from the piston to the head if all is fitted. Can there be an contact between both? all bearings are new.
thx,Jan
thx,Jan
