Hello Turbo Friends,
I tought its time to share some info with you. Im currently almost done with sorting parts out for my second 4E build. First one died due to wrong advice. But now after long nights of doing research and a bit of my own knowledge and the builders knowledge i decided its time for the second build. So im postin a little bit of info on the engine so you can give your input and advice on it.
-Bone stock 4EFTE to rebuild
-Ross 74.5mm Forged pistons
-SCAT HBeam Rods with ARP bolts
-Complete ACL Aluglide bearing set (Main,Rods,Thrust)
-ARP Head bolts
-1.6mm Cometic MLS Headgasket
-Toyota Overhaul Gasket Kit (all seals)
-New Timing Belt and Tensioner
-Tial 38mm External Wastegate
-T28 Turbo. (But thinking of buying a GT2860RS .63 A/R Exh Housing)
-Head remains as is (not planning to modify it)
-Speedvision double core Aluminum Radiator and fan
-Front mount intercooler (27x6x2.5)
-New dizzy rotor and cap
-440cc RX-7 Injectors
-Walbro 255 fuel pump
-AEM Fuel Pressure Regulator
-Haltech Sprint 500 stand alone ECU
-Greddy Profec E-01 Boost controller
-Stock ignition (planning on getting a MSD6A and a MSD Coil for better spark)
Also planning to skim the head and deck the block for perfect fitment of headgasket. Compression ratio would be around 8.3:1 with this setup.
Planning to to run about 1 or 1.1 bar daily and 1.6 at the track(once a month).
Your advice and knowledge and experience on this build in much appreciated.
Cheers:rockon:
-ARP Head bolts
Cheers:rockon:
