CT9 Hybrid - Downpipe - Stock pistons + Rods + Lots more
GP82
For sale: Stock valve springs
Item Condition: Used
Price and price conditions: £30 inc.del
Extra Info: N/A
Pictures:
Contact Details: PM
Delivery & Conditions of Delivery: Collect or send out Royal Mail
For sale: TD04L turbo oil feed bolt
Item Condition: New
Price and price conditions: £10 inc. del
Extra Info: Turbo oil feed bolt with the bigger hole
Pictures:
Contact Details: PM
For sale: CP Piston Wrist Pins
Item Condition: New
Price and price conditions: £55 inc. del
Extra Info: Pin Diameter: 0.708", Pin Length: 2.25", requires 0.050" lock wire
Pictures:
Contact Details: PM
For sale: Stock front brake lines
Price and price conditions: £6 inc. del
Extra Info: N/A
Pictures:
Contact Details: PM
For sale: Thermostat seal, Downpipe/decat to exhaust flange gasket
Item Condition: New
Thermostat seal £2.50 inc. del
Downpipe/decat gasket £2.50 inc. del
Extra Info: N/A
Pictures:
Contact Details: PM
For sale: Stock clutch line
Price and price conditions: £3 inc. del
Extra Info: N/A
Pictures:
Contact Details: PM
For sale: CT9 oil feed/drain pipe and CT9 water pipes
CT9 oil feed/drain pipe £15 inc. del
CT9 water pipe £10 inc. del
Extra Info: N/A
Pictures:
Contact Details: PM
For sale: Stock recirc valve.
Stock recirc valve £10 inc. del
Extra Info: N/A
Pictures:
Contact Details: PM
For sale: Toyota shims for valve clearance
Price and price conditions: £6 each inc. del
Extra Info: Sizes i have:
0.118" (2.997mm) x2
0.119" (3.023mm) x3
0.120" (3.048mm)
0.121" (3.073mm)
0.122" (3.099mm)
Pictures:
Contact Details: PM
For sale: TD04l/IHI turbo Actuator
Price and price conditions: £25 inc. del
Extra Info: 0.8 bar arm/spring tension
Pictures:
Contact Details: PM
Thank you for looking.
wildchild
sorry for the off topic question, but what valve springs are you using now?
if they are uprated, then what model, make and what power gains did you achieve?
GP82
Hey, I am using the Cruise full boost strengthned valve springs. They are from www.rhdjapan.com
Have a look here:
http://www.rhdjapan.com/cruise-full-boost-strengthened-valve-springs-starlet-4e-5e-14730
Power gains that i can feel is that the engine continues to breathe efficiently at high rpm (from 6800rpm to 8500rpm) because the valve springs retain better control of the valve within the cylinder head where as the stock valve springs (which are more then capable) can loose control of the valve at high rpm (when the springs get old because of long service) and will loose cylinder pressure. I can actually hear the engine noise which is different at high rpm and also feel that the engine is breathing efficiently. In my opinion a very good upgrade if you are rebuilding the cylinder head, especially with a higher lifting camshaft profile.
Check out the build thread, it has got the pics of the Cruise valve springs, you can physically see that the valve spring wire is much thicker and waaaay stiffer the the stock ones.
http://www.toyotagtturbo.com/forums/showthread.php?101906-4EFTE-Build-Pics
wildchild
thanks for the info. im running FHE cams on stock springs.
i shift at 7500. it seems i hit over rev at around 8500 if im right. at around 6000rpm my wheel spun and went all the way pass the redline in a flash. not sure on da overrev range as my eyes were glued to my opponents car ;)
thinking of upgrading to the 262 262 billet cams from svcps..
5e colin
hey there a freind of mine in nederland (holland) needs some 4efte valvesprings will u post them to nederland
yimbug
Torque wrench, valve grinder and valve compressor
Cheers bud, received these yesterday well chuft, pleasure doing business :D
