ep70 boxy gearbox change help to 5 speed !!!!
ciaran o mahony
I am changing my gearbox in my 1ltr ep70 and was wondering as the splines on the driveshafts dont line up I have a glanza in the yard aswel would I convert all front hubs/driveshafts/gearbox ??? or is there an easier way out ??
5e colin
drives will fit ciaran should be no bother there depending wa car the 5 pot comes out you might need to swap mounts around to the starlet 1s
also bracket on the box to hold cables in place might need swaping ( i had to when fitting rolla box in my ep82 )
ciaran o mahony
spider bearings are also smaller on the original 1l driveshhafts to the 1.3 box
Stu-
Thats weird as I've swapped ep82 5spd boxes onto a couple of 1e engines and use the original 1e shafts/inner cv's into the 4e box.
