RRFPR fittings sizes
MarcoGTTurbo
Hey all,
Going to be installing my Turbosmart RRFPR this weekend. It didnt come with any fittings so will need to go out and buy these tomorrow. Ive tried searching the forums but cant find the specific info I need? What size fittings do I need for the inlet and outlet on the reg? Its the barbed bit I need the sizes for. I can take in my reg to the motor factors to get the thread size so not too worried about that.
Im guessing Ill need the same size barbed fitting for the fuel rail adapter also?
Cheers for the help guys
Mark
MarcoGTTurbo
thanks garry, Ive just been on the turbosmart website and there is 2 sized barbs for my rrfpr. Theres a 6mm barb and an 8mm barb.
Theres a thread on here that I found last night on how to fit a rrfpr and he uses 1/4inch (6.4mm) fuel line. Would I use the 6mm barb or 8mm barb for that?
cheers
MarcoGTTurbo
All fitted now guys. Went with a 8mm barbed fitting and 6.4mm fuel line with 3mm vac line.
Ive set the pressure to 34psi which is roughly the same as stock.
Now time to get the HKS FCD sorted up the boost and then onto the dyno for a setup and bit of a tune
cheers
