Results 1 to 19 of 19
    Mar 2008
    Sunny Sheffield
    198
    Default STeering Wheel shaking on idle
    My steering wheel shakes/vibrates when my car is idling, is this engine mounts or something else???? Need to know
    Cheers guys
    Banned
    Huddersfield, West Yorkshire.
    12,055
    Reputation: 1067 Members Garage: 3
    Is the car idling low? I guess so? It should be idling at 900rpm, are yours revs dropping below that on idle?
    Mar 2008
    Sunny Sheffield
    198
    not really pretty much as i would expect between 750-900rpm when warmed up.
    Banned
    12,055
    Hmm. Not sure then, could be your engine mount as you stated but I don't know. Mine used to idle low and the steering wheel would shake until the car was revved. Turned out that was the only problem.
    Banned - DO NOT BUY FROM TOYTUNING
    Aug 2003
    Surrey, UK
    9,488
    Worn engine mounts will cause excessive steering vibration if the car is stationary. Worn ball joints and track rods will also cause excessive movement and so will a shot steering rack. If your moving and it's vibrating then the wheels are out of balance and need re-weighting.
    Tobs
    Registered User + thomllee1981's Avatar
    Rhyl, North Wales
    871
    Reputation: 90 Members Garage: 1
    Quote Originally Posted by Toby View Post
    Tobs
    Tobs can you clarify whether the ball joints track rods or shot rack is when stationary or moving as i also have this issue but with mine being an auto not sure what my revs should be at when stationary.
    Registered User + kieran.s gt's Avatar
    Jan 2008
    co.cork,ireland
    3,488
    Reputation: 3176 Members Garage: 1
    Quote Originally Posted by LONGY0710GTTURBO View Post
    Cheers guys
    ya it happens when idling low happens mine
    anyone know how to raise the idle
    Registered User + chinaone's Avatar
    North London
    1,527
    Reputation: 204 Members Garage: 1
    Mines does that too, some time it stays at 600, and sometimes it drops way below and comes back up, normally when i see that happens, i rev it back up, and its all fine, what can i do to make the idle steady?
    Banned
    12,055
    You can adjust the idle from the screw on the throttle body. Or mess with the dizzy cap.
    Aug 2003
    Surrey, UK
    9,488
    Adjusting the idle is a temp fix you need to really find out why the idle is so low in the first place, I would check the idle control valve first and ensure that the car is well earthed. The elecrtical systems on the Starlets are weak, coupled with a small battery and years of driving they soon pitter away. Alternators are also a big cause of problems we end up re-furbning most that come in as they have seen better days especially as most add quite a few power sapping gadgets.
    If ball joints are worn you will see movement in the steering wheel from left to right at slow speeds, over 60mph and it will be less due to the inertia created by the wheels. Track rods will evoke steering play and so will worn rack bushes. If the rack bushes are really gone then you will feel vibration but worn engine mounts will be a major cause. How much vibration are we talking? Obviously if the idle is low it will cause excessive vibration but if runniung a normal idle then you need to look else where. Don't forget adjusting the idle screw effects the base timing so be a little wary of just adjusting it to suit.
    Tobs
    Paid Member sx_turbo's Avatar
    Canvey Island, island of dreams
    14,042
    Reputation: 2755 Members Garage: 2
    if you have worn engine mounts, or TRD engine mounts or stronger ones, then you will suffer from your steering wheel shaking.
  12. #12
    Aug 2003
    Surrey, UK
    9,488
    I was going to say that with uprated engine mounts you will feel more vibration on the car in general not specifically through the steering wheel, if it's just the steering wheel then I would say there is excessive movement somewhere. You can easily test the mounts, get a friend to watch the engine, put the car in 5th gear, gently bring the clutch out when stationary, not enough to stall just enough to load the engine you will know if it's moving excessively. I used to have a video of this showing what it would look like with buggered mounts but can't find it think it was on the old PC.
    T
  13. #13
    Paid Member Elaine's Avatar
    Weymouth, Dorset
    2,672
    My Steering wheel shakes for a past time so does the rest of my car, I put it down to my TRD engine mounts????
  14. #14
    Mar 2008
    Sunny Sheffield
    198
    thought you might have posted on this thread elaine after seeing "vibrates".
    Just playing.
  15. #15
    14,042
    Quote Originally Posted by GT_Elaine View Post
    thats because it is elaine, dont worry your pretty lil head.
    theres just a lot of scare mongering on here
  16. #16
    Weymouth, Dorset
    2,672
    Just playing.
    Hahahaha thats so rude!!
    Quote Originally Posted by sx_turbo View Post
    lol Ricky I was not worried I like the "vibrations"
  17. #17
    Mar 2008
    Sunny Sheffield
    198
    Had a feeling you liked the vibrations,
    you'd like my glanza vibrates like mad, (read into that what you like)
  18. #18
    Weymouth, Dorset
    2,672
    lol such a shame you live on the other side of the world
  19. #19
    Mar 2008
    Sunny Sheffield
    198
    why interested in the vibrations????
    we'll talk on msn later elaine
