Results 1 to 15 of 15
    Technical Moderator Dub-Se7en's Avatar
    Stoke-on-Trent
    4,598
    Reputation: 1804 Members Garage: 2
    Default 4EFTE Torque Specs
    courtesy of CustomEP. rep him if you find it useful
    Starlet Sportif Turbo
    lots of useful stuff here
    Oct 2007
    Walsall YAM YAM
    2,718
    Reputation: 587 Members Garage: 1
    215
    some more....
    4E-FTE Engine Service Specifications.
    Cylinder Head:
    Warpage limit (block side) 0.05mm
    Warpage limit (Manifold side) 0.05mm
    Intake manifold:
    Warpage limit 0.1mm
    Exhaust manifold:
    Warpage limit 0.2mm
    Cylinder block:
    Surface warpage limit 0.05mm
    Bore diameters:
    STD mark 1 = 74.000-74.010mm
    STD mark 2 = 74.010mm-74.020mm
    STD mark 3 = 74.020mm-74.030mm
    Limit before rebore = 74.23mm
    Piston diameter:
    STD mark 1 = 73.900-73.910mm
    STD mark 2 = 73.910mm-73.020mm
    STD mark 3 = 73.920mm-73.930mm
    Piston to oil clearance:
    STD = 0.09-0.11mm
    Limit = 0.13mm
    Piston ring groove clearance:
    Top ring = 0.04-0.08mm
    2nd ring = 0.03-0.07mm
    Piston ring end gap:
    Top ring (STD) = 0.26-0.36mm
    Top ring (Limit) = 0.95mm
    2nd ring (STD) = 0.15-0.30mm
    2nd ring (Limit) = 0.90mm
    Oil control ring (STD) = 0.13-0.38mm
    Oil control ring (Limit) = 0.98mm
    Con-rods:
    Thrust clearance (STD) = 0.15-0.35mm
    Thrust clearance (Limit) = 0.45mm
    Big-end inner diameter:
    STD mark 1 = 43.000-43.007mm
    STD mark 2 = 43.007-43.014mm
    STD mark 3 = 43.014-43.021mm
    U/S 0.25 = 43.000-43.021mm
    Rod bearing centre wall thickness:
    STD mark 1 = 1.487-1.491mm
    STD mark 2 = 1.491-1.495mm
    STD mark 3 = 1.495-1.499mm
    U/S 0.25 = 1.607-1.613mm
    Con-rod oil clearance:
    STD = 0.016-0.048mm
    Limit = 0.08mm
    Maximum allowable bend in rod per 100mm = 0.03mm
    Maximum allowable twist in rod per 100mm = 0.05mm
    Crankshaft thrust clearance:
    STD = 0.02-0.20mm
    Limit = 0.30mm
    Main journal oil clearance:
    STD = 0.016-0.049mm
    U/S 0.25 = 0.017-0.061mm
    Limit = 0.08mm
    Main journal diameter:
    STD mark 0 = 46.995-47.000mm
    STD mark 1 = 46.990-46.995mm
    STD mark 2 = 46.985-46.990mm
    Main bearing centre wall thickness:
    STD mark 1 = 1.995-1.999mm
    STD mark 2 = 1.999-2.003mm
    STD mark 3 = 2.003-2.007mm
    STD mark 4 = 2.007-2.011mm
    STD mark 5 = 2.011-2.015mm
    U/S 0.25 = 2.115-2.123mm
    Crank pin diameter:
    STD = 39.985-40.000mm
    U/S 0.25 = 39.745-39.755mm
    Limit = 0.06mm
    Circle runout (Limit) = 0.06mm
    Main journal taper and out-of-round (Limit) = 0.02mm
    Crank pin taper and out-of-round (Limit) = 0.02mm
    Torque settings:
    Cylinder head bolt:
    First 36ftlb
    Second - turn 90 degrees in same sequence
    Cylinder head to camshaft bearing cap:
    9ftlb
    Cylinder head to intake manifold:
    14ftlb
    Cylinder head to exhaust manifold:
    35ftlb
    Cylinder head to water outlet housing:
    13ftlb
    Cylinder head to Cylinder head cover:
    61inlb ** note inch pounds, not foot pounds! **
    Camshaft to Camshaft timing pulley:
    37ftlb
    Cylinder block to crankshaft bearing cap:
    42ftlb
    Cylinder block to rear main oil seal retainer:
    65inlb ** again note inch pounds **
    Cylinder block to oil filter union:
    18ftlb
    Crankshaft to flywheel:
    65ftlb
    Con-rod cap to con-rod:
    29ftlb
    Oil pump pulley to drive rotor:
    27ftlb
    Super Moderator Zisco Performance Section HYBRID's Avatar
    Malta!
    19,760
    Rep added accordingly!
    Nice one guys!
    Kon
    215
    tnx guys
    Stoke-on-Trent
    4,598
    Quote Originally Posted by lleey2k4 View Post
    yep it's there too but people seem to be missing it i thought i'd post it here. remember to rep Tom (and sagittarius now) for the info.
    Nov 2008
    uk
    129
    Default 1
    what does it mean by stage 2 90 sequance, also stage 1 stage 23 and stage 3 90 dont u just tighten the head bolts
    Paid Member nexia201's Avatar
    Aug 2008
    Malta
    1,044
    Reputation: 208 Members Garage: 1
    Quote Originally Posted by nav799 View Post
    yes but in stages so its tightened gradually
    Nov 2008
    uk
    129
    Default h
    so u thghten the bolts and drive certain miles then take the head cover off and thghten again the bolts like that or just thighten them. also u have to take off the cams and timing belt to thghten the bolts as that what u do or any other way
    Stoke-on-Trent
    4,598
    no just do one stage, wait a short while, then do the next.
    Sep 2008
    Falkirk
    256
    do ARP rod bolts just get torqued to those valuues or are they different?
  12. #12
    Jun 2008
    lancashire
    57
    Reputation: 11 Members Garage: 1
    Default shimm settings
    hi i nieed to know the camshaft shimm settings if any body can help me please ?? cheers , dave
  13. #13
    Feb 2010
    midlands
    66
    head bolts dont need replacing?? :s i presume they are not stretch bolts then??
  14. #14
    Feb 2010
    Sennybridge, South Wales
    65
    nice 1 guys...didnt understand the stages myself an youve made it all clear now, thanx for this very helpful post...rep added to all!
  15. #15
    Paid Member weeJohn's Avatar
    Co. Antrim
    6,245
    Reputation: 3797 Members Garage: 2
    Took a pic of this the other day for a lad questioning torque specs, its from a Toyota 4E workshop manual so its genuine. If the section admins think its worthwhile sticky it in the torque spec posts please.
    243 bhp, 210 ft/lbs of torque, 4 wheels to put it through
