Results 1 to 21 of 21
    May 2008
    Davao City Phils
    934
    Default safe boosting for a ct12 "1GGTE"
    whats the most safest boost we can put into this turbo? without the fueling mods. thanks
    thanks
    UK
    4,115
    Reputation: 1450 Members Garage: 1
    You manage to get this to fit then mate? Did you use a CT9 exhaust housing? Pics?!
    May 2008
    Davao City Phils
    934
    Quote Originally Posted by ChrisGT View Post
    i manage to fit this by using a ct9 exhaust housing, rotating the compressor housing to mate the actuator rod to the arm. extending the acuator rod using a bolt and a long nut so that ill not change the wastegate arm. and a bit modification on the compressor side
    enjoy.. hope this helps
    May 2008
    Davao City Phils
    934
    bigger exhaust wheel and compwheel
    good powerband
    provides better toque than ct9
    South Wales, UK
    5,540
    Reputation: 532 Members Garage: 1
    Quote Originally Posted by RGM1800 View Post
    thanks
    Probably around 0.6 bar. A stock setup will fuel cut at around 0.7-0.8 bar iirc on a CT9 and I'd wager that the CT12 would flow a lot more air at the same pressures.
    Best bet would be to sort your fueling out and wind the boost up.
    Paid Member Jay's Avatar
    Oct 1977
    County of Down, Northern Ireland
    11,533
    Reputation: 5021 Members Garage: 5
    Hard to say from here. Best advice I can offer is to break out the wideband and play it by ear mate.
    Neat modifying BTW. Very tidy.
    http://img392.imageshack.us/img392/6652/520780toyhn0.gif
    Check my trading forum - jaysgarage.toyotagtturbo.com
    Check my feedback - HERE!
    UK
    4,115
    That looks awesome ! Make me one!
    May 2008
    Davao City Phils
    934
    im from the philippines but its too far to send you one
    but i can assit on your proj.
    May 2008
    Davao City Phils
    934
    thanks for the replies.
    so 0.6 is the best bet?
    Oct 1977
    11,533
    Doesn't matter what boost you run I'd still advise a fuelling run with a wideband. I'm not 100% sure what tuners are local to you but it's highly recommended mate.
    No point guessing - you could be missing free power or risking damage for the sake of it.
    May 2008
    Davao City Phils
    934
    Quote Originally Posted by Jay View Post
    thanks for the appreciation but my actuator is a bit shitty no time to make it look good.
  12. #12
    UK
    4,115
    What did you have to modify on the compressor side?
  13. #13
    May 2008
    Davao City Phils
    934
    you have to relocate the vac signal so it wont hit the bolts near the oil filter. relocate it near the outlet. like the td04 and the ct26 ones.
  14. #14
    UK
    4,115
    Oh I see, the CT12 vac source is round the back, so how'd you do it? Drill and weld?
    Did the CT12 exhaust wheel fit in the CT9 exhaust housing without porting it?
  15. #15
    May 2008
    Davao City Phils
    934
    drill the force fit the weld it
    you need to port the exhaust housing when you use the ct12 exhaust wheel.
    it should be machined porting not the dremel.
    if you don want to port the exhaust housing then use the ct9 exhaust wheel
  16. #16
    UK
    4,115
    Go on mate, make me one...you know you want to
  17. #17
    May 2008
    Davao City Phils
    934
    ill try to find time adn source another ct12s like these.you can do it bro. it needs a bit of patience and a lot of guts.
    just sent an email to monka. its a compilation pics of the ct12 that i got.
  18. #18
    UK
    4,115
    I'd don't have the facilities to machine/weld, so would have to get someone to do it in which case I might as well just fork out and buy a pre-built Hybrid!
  19. #19
    May 2008
    Davao City Phils
    934
    im planning to make you one but ill try to source if we can get another ct12.
    now i dont have a price for the hybriding. do still have your aircon? we can make a custom spec turbo like this
    hybrid 9/12
    ct12 compressor housing and internals mated with a ct9 exhaust housing
    custom adjustable actuator or a custom wastegate arm.
    ported wastegate
    fully balanced
    new seals
    thats what i have in mind right now
  20. #20
    Jul 2008
    cornwall
    346
    Default Awsome
    Awsome idea, spot on, if i could find the parts id do the same!!!!
  21. #21
    Jun 2008
    St.lucia
    306
    just got my hands on 2 ct12 and will be doing this same thing to use on my 5efte project
    plan is to run 1 bar of boost
