greddy injector adaptor no.2 info
Chris@CCM
hi guy from reading loads of guys saying u must use the greddy injector adaptor no.2 with all emu board i just thought i would post up some in from the greddy site as with all later boards ive never found ive needed one.
so you can see from serial number 4000 its built in to the unit
hope this is use full for some ppl
goldenvtr
cool ill need to check my serial number but i dont have any rich issues that i know off- seems to be adding and reducing fuel as it should do but i do have one of the later boards
danturbo4311
Anyone no if it will cause any problems if you run an injector adp. no. 2, with one of the above units which has it built in or is it just a case of theres no point, as i already purchased this adaptor & my ultimate unit is only 2 months old gonna be wiring it in next week.
FeNder
i think the newer versions have it built in , starting from the D version if i remember right ,
mine is a B and i did need it , check ur version with the letter on the board .
