Results 1 to 4 of 4
    At 9,000rpm
    11,529
    Reputation: 471 Members Garage: 2
    Exclamation Oil pressure relief valve?
    As title, where is this on the 4efte?
    Anyone have one of those engine pictures with part numbers or can just explain where it is?
    Toyota says it does not show on the 4EFTE but does on the 4EFE??
    Thanks.
    Paid Member sx_turbo's Avatar
    Canvey Island, island of dreams
    14,042
    Reputation: 2755 Members Garage: 2
    i think its where the oil pick up is but i cant remember.
    i have a corolla haynes manual at home i find very handy.
    2,869
    hey gee......if i'm on the same wave length as u
    then the oil pressure relief valve is located on the inside of the block ----it screws into the block from the underside and i think its a 17-19mm bolt looking thing-----has a little clip and spring mechnism in it
    and for sure one is in the 4efte........and all other e series engines i have seen
    http://homepage.ntlworld.com/richard...k/15L_4_CY.pdf
    look on page 34 and u will see what it is
    At 9,000rpm
    11,529
    Cheers, I'll pass this information on.
