hope this helps a bit mate "found on this site. posted by
dave@tm-developments.com"
Torque settings:
Cylinder head bolt:
First 36ftlb
Second - turn 90 degrees in same sequence
Cylinder head to camshaft bearing cap:
9ftlb
Cylinder head to intake manifold:
14ftlb
Cylinder head to exhaust manifold:
35ftlb
Cylinder head to water outlet housing:
13ftlb
Cylinder head to Cylinder head cover:
61inlb ** note inch pounds, not foot pounds! **
Camshaft to Camshaft timing pulley:
37ftlb
Cylinder block to crankshaft bearing cap:
42ftlb
Cylinder block to rear main oil seal retainer:
65inlb ** again note inch pounds **
Cylinder block to oil filter union:
18ftlb
Crankshaft to flywheel:
65ftlb
Con-rod cap to con-rod:
29ftlb (18ftlb then +90 degrees)
Oil pump pulley to drive rotor:
27ftlb
pulled this from a scat rods site
7/16" x 1.500" SCAT 2001 cap screw 63 ft./lb w/ARP moly (.0050" stretch)
7/16" x 1.800" SCAT 2001 cap screw 63 ft./lb w/ARP moly (.0060" stretch)
