hey texx i have now the resistance. measured after 20kms of driving.
i measured it whiel the sensor was bolted on the thermohousing. and water is also drained. its 274 ohms. is that ok?
and also measured the intake temp sensor its 537 ohms.
If the engine was still hot when you measured the resistance of both sensors, then yes I'd say they were OK.
whats the sensor before (facing the engine) the ect sensor?
I'm not 100% sure which sensor your referring to, but it's probably the sender for the temperature gauge in the dash.
TBH without looking I couldn't say for certain, but it's possibly a coolant temperature sensor for the A/C amplifier.
