i believe they may have sent the incorrect mount..
not sure if it matters but mine are yellow :noidea:
..i'll get the part number when i get home later on
EP82 and EP91 may vary in sizes ! did you order an EP91 bush by mistake ?
was your car an auto? if its need converted the mount fit the manual box but is a larger bush.
also, how come your bush is blue??? mine are all yellow?
Wesbite doesnt let you specify EP82 or EP91
https://store.nexternal.com/powerfl...turbo-ep82--ep91-urethane-bushings-p1135.aspx
Does the gearbox have the OEM LSD?
If so then they wont fit that mount.
If not then i have a brand new powerflex gearbox mount bush in my garage you can have.
Doesnt fit mine due to LSD but they came as a full set so it just sitting there in the box now.
I think i have my old OEM LSD mount in my garage.
I'll measure the diameter and post a pic on here for u fella.
starlet bushes dont keep the original shells.
i also fitted new bushes to a dogbone mount off a clio and that required the old bush shells to be removed.
even if he kept the original shell the bush would still be too small.
i fitted polly std offset front arm rear bush's to my gt and they used the original sleeves !
just an idea iv seen this alot on other cars
