valve clearances
woff
Just wondered if anyone knew what the official figures are on a ep91 4efte. seen lots of figures all different and dont know what to go with!! 0.17 - 0.23mm on intake or 0.06 - 0.08 and exhaust >> 0.27 - 0.33mm or 0,08 - 0.12?? im baffled:homer:
Texx
4E-FTE Valve clearance with the engine cold are:
Intake 0.17mm - 0.23mm
Exhaust 0.27mm - 0.33mm
Texx
That the same for aftermath cams also?
Personally I would stick to using the stock clearance spec unless otherwise stated by the camshaft manufacturer.
does it apply to 4e/5e?
The above valve clearance spec comes from the JDM workshop manual that covers both the 4E-FTE and 5E-FHE engines.
The USDM 5E-FE manual gives a valve clearance spec of:
Intake 0.15mm - 0.25mm
Exhaust 0.31mm - 0.41mm
Personally I'd go by the JDM spec, it seems a little more precise.
