sdutton007
Hi,
Earlier I ran out of fuel (stupid I know), managed to get it started again long enough to get it out of the road before it cut out again.
After work, put some fuel in it, but still wouldnt start - the starter noise is normal (or as normal as it was before) and definately has compression.
Figuring it was probably a clogged fuel filter, I took the top hose off the fuel filter and very little fuel came out even with the ignition on. Only while the starter motor engaged did it chuck out fuel (and a decent amount, so clogged filter doesnt seem to be the problem)
So I took the king lead out, placed it near an earthing point of the car and tried starting - no sparks jumping.
From my limited knowledge, I'm guessing either the Coil Pack or the Crank sensor...
Could anyone please enlighten me what's most likely to have suddely packed in while I was driving and what would be the best way of testing it. I have a written off starlet I'm stripping for bits so parts shouldn't be a problem.
Please help! Thanks!
