how to change fan belt on starlet na ?
jimmymac101
as in title im after some help on how to change the fan belt ? i cant find any where that gives a straight answer :( if any one has a picture guide or can explain how to do it that would be brilliant :)
cheers james
Loosen off PAS pump this will let you remove the front belt Loosen the alternator this will let you remove the rear belt tension the belts back up after you have replaced them
Texx
This may help a little:
Power Steering Belt
Alternator Belt
