Results 1 to 5 of 5
    Fresh to the site
    Jun 2010
    Namibia
    33
    Default Toyota gearboxes?
    4 Speed transaxles
    C140
    A 4-Speed Manual Transmission for FWD cars.
    Gear ratios
    1st 2nd 3rd 4th Reverse Final
    3.545 1.904 1.310 0.969
    Applications:
    Toyota Starlet
    5 Speed transaxles
    C50
    A 5-Speed Manual Transmission for FWD cars. This gearbox is known to develop a fifth gear pop out problem as it ages, primarily due to worn shifter detents caused by the driver resting their hand on the shifter. (This was supersede by C52 Transmission) Is used in the early mk1 (AW11) MR2.
    Gear ratios
    1st 2nd 3rd 4th 5th Reverse Final
    3.545 1.904 1.310 0.969 0.815 3.250 3.722
    Applications:
    88-92 US Toyota Corolla 2WD SW, SEDAN, SR5
    Toyota MR2
    C52
    A 5-Speed Manual Transmission for FWD cars. This will fit most Toyota A series engine [1] Is used in the later mk1 (AW11) MR2.
    Gear ratios
    1st 2nd 3rd 4th 5th Reverse Final Differential Gear Ratio
    3.166 1.904 1.310 0.969 0.815 3.250 4.058 3.722
    Applications:
    88-91 US Toyota Corolla GTS
    Toyota Starlet GT Turbo
    Toyota MR2
    Toyota AE101 Levin/Trueno
    C56
    Gear ratios
    3.166 1.904 1.392 1.031 0.815 3.250 4.312
    Applications:
    Toyota Celica
    Toyota Corolla
    Toyota Starlet Glanza V
    Toyota AE101 Levin/Trueno (Later Years only)
    Toyota AE111 Levin/Trueno
    Toyota MR2 Spyder (US/UK/JP) (mid-engine application)
    C58
    Gear ratios
    3.545 1.904 1.233 0.969 0.725 3.250
    C59
    A 5-Speed Manual Transmission for FWD cars. Similar to C52 but stronger.
    Gear ratios
    Applications:
    Toyota Matrix
    Toyota AE102 Corolla (Australia)
    C150
    Gear ratios
    3.555 1.904 1.310 0.969 0.815 3.250 4.058
    Applications:
    Toyota Starlet Gi
    Toyota Echo 2000-2005
    C153
    A 5-Speed Manual Transmission for FWD cars including a limited slip differential.
    Gear ratios
    3.545 1.904 1.310 0.969 0.725 3.250
    Applications:
    6 Speed transaxles
    C60
    Gear ratios
    1st 2nd 3rd 4th 5th 6th Reverse Final
    3.166 2.050 1.481 1.166 0.916 0.725 3.250 4.529
    Applications:
    2000-2005 Toyota Celica
    Toyota Corolla
    2003-2006 Toyota Matrix XRS
    2003-2006 Pontiac Vibe GT
    2003-2007 Mr2 Roadster/Spyder
    beware, Bell housings marked with the C60 stamp are also used on other gearboxes other than the 6speed, some J-spec 5 speeds also have this marking as well[citation needed]
    Fresh to the site
    Jun 2010
    Namibia
    33
    I have a few questions on the above?
    1. an anyone confirm that all this info is correct
    2. Will the C50,C150,C153 work on a EP82
    3. Will the C52 really fit most Toyota A series engine
    4. Will a C56 fit the EP82
    5. Is the C59 really Similar to C52 but stronger. Will it fit an EP82
    6. Is there any 6 speed box that will work on an EP82 - if so is it worth it
    Supermoderator azerty's Avatar
    Mauritius
    2,119
    Reputation: 603 Members Garage: 3
    C56 gearbox from glanza will fit EP82 but the final drive is not 4.3, it is the same as GT (C52) which is 3.7
    May 2010
    Nairobi, Kenya
    2,737
    doing a lot of homework on trannies so bear with the noob questions..
    for daily driveability, which final drive is preferred, 3.7xx or 4.2xx..?
    Apr 2009
    Cork ,Ireland
    963
    I prefer longer gears anyway I find the gt box I am using now that the gears are way too short my ep71 t box had longer gears which I preffered
