Martin Broon
can any 1 give me the valve clearance for the inlet and exhaust side for a 4efte please
if they are not respected , what kind of problem can we get Texx ?4E-FTE Valve clearance with the engine cold are:
Intake 0.17mm - 0.23mm
Exhaust 0.27mm - 0.33mm
A valve clearance that's too tight will cause a loss of compression and likely result in a burnt out valve or valve seat.
A valve clearance that is excessively loose could eventually cause wear to the corresponding cam lobe.
A loose valve clearance is better than a valve clearance that's too tight.
an about a high temp ? is there a relation?
Thats why the clearance is greater for an exhaust valve, the intake valve gets cooled by the intake air and fuel spray.
