Results 1 to 11 of 11
    May 2010
    Milton Keynes, UK
    2,538
    Post Car cigarette lighter/power socket not working?
    As above!
    Last used on Monday for satnav with no probs. Rarely used to be honest.
    I understand that the fuse must've blown but why? Also where and what fuse is that?
    Thanks a lot.
    Paul
    Sperrin Mountains, NEEH!
    1,271
    Reputation: 637 Members Garage: 1
    I've blown the same fuse, replaced it and it was sound. I think I blew it when plugging in mobile charger, but its been sound since.
    Nov 2010
    Oxford
    3,160
    Check the fuse and also check you haven't knocked off the connector on the back, sometimes they can come off pretty easily.
    May 2010
    Milton Keynes, UK
    2,538
    Quote Originally Posted by AdamB View Post
    I've read something about that on the yahoo answers but I've no idea how it should look like?
    May 2010
    Milton Keynes, UK
    2,538
    Quote Originally Posted by SupaStu View Post
    Do you remember which one by any chance?
    1,271
    I think its under the dash under CIG.
    Nov 2010
    Oxford
    3,160
    It is connected behind the dash mate, can't remember exactly been a while since I had mine out. Theres two push on connectors and I also think theres a plug. I doubt the plug will come out, but maybe one of the connections have popped off if you've pushed anything in the socket to hard.
    Paid Member weeJohn's Avatar
    Co. Antrim
    6,245
    Reputation: 3797 Members Garage: 2
    Plug can come off the back, but also the metal strips on the back of it can go bad as well. You can remove it easily to check it all and you can replace the bottom connections with a UK spec one as well.
    243 bhp, 210 ft/lbs of torque, 4 wheels to put it through
    May 2010
    Milton Keynes, UK
    2,538
    Thanks everyone it's sorted now.
    The fuse was fine, the connectors on the back were fine as well. There was a piece of plastic in the middle which was blocking the cenral pin to connect, 10 sec fix really.
    My fuse said CIG/RAD - and I found that I have no fuse at all for Def - the bottom one in the middle column... anybody else got that missing? And why is it CIG/RAD??? what's rad? radiator???
    1,271
    Cigar/cigarette and radio
    If you check the DEF one you will probably find there is no metal insert to allow a fuse to fit. I think its just a standard fuse layout template for toyotas. I have three missing, but there are no inserts, so you cant add fuses.
    May 2010
    Milton Keynes, UK
    2,538
    Right, that's good to hear. Thanks a lot for your help!
