4eftetercel
Does anyone know what the voltage should be at idle and what it should be at WOT? I know the TPS is pretty much an on/off switch
Here is the problem i am having, with the TPS plugged in and adjusted properly the car wont rev pass 2000 RPM. it just cuts out then revs to 2k again then cuts out and it keeps doing this in a loop if i hold the throttle steady. i have a nissan sentra SE-R TB and it opens in the opposite direction of the toyota.
here is what i discovered, with the TPS disconnected the car drives perfect. when i adjust the tps so the middle pin is not touching any of the other 2 pins the car revs fine and the AFC reads 5 volts. (the same effect as disconnecting the tps) when the tps is in the WOT position the afc read zero voltage. It seems to me as if this is backwards, can anyone help shed some light. Thanks. See pics below for better understanding.
3 wires for the tps im wondering if the bottom yellow/red wires have switch position in the harness? notice how one loops over the other? I'm thinking maybe the person that installed my AFC swapped these around since the nissan TB closed position would be wot on the toyota tps?
This pic show the tps in idle position as it would be if bolted on the TB. With these 2 pins touching the AFC read 5.0V
With the middle pin in this position, not touching either, the car revs and drives fine but runs a little rich so i use the afc to lean out. the AFC still reads 5.0 V
With the middle pin touching the bottom at WOT i get 0 V on the AFC
why does not rev past 2k when the middle and top pins touch (brown and yellow/red), reading 5 volts vs when the 2 pins are not touching it still reads 5 volts but revs past 2k?
