ep91 to ep70
rwdstarlet
hi i have a glanza da bodys ruff and i want 2 build a drag car so i bought a ep70 to do a conversion, now iv been looking it up on da site and all i can c is ep82 to ep70 conversions, will da glanza parts not fit da same as da gt ones????? any help on this topic will be grate, thanks lads.
Sagittarius
ep91 to ep70 is the same as ep82 to ep70. Done this a few times, just make sure you make a good loom with a circuit opening relay. If you don't and you crash the car the fuel pump will keep pumping which is not something you want if the car catches fire.
I can post a diagram I made for that ep71 loom, you just have to match the ep91 wires to the ep82 wires.
Sagittarius
Here is the diagram. Please note that the relays (A1 and A2) are used from some sold ep82 aircon relays)
Plug B is a plug i used to connect some wires to a walbro fuel pump in the engine bay, and some other things
Also note that this diagram includes an fcd.
Click Here
GT
