We charge a base rate of £1000.00 for a 4efte conversion exc parts. The loom has to be spliced which is quite complicated and takes time to do and we've done quite a few before, we were one of the first in the UK to have a 4efte UK spec Starlet after Chall and Tony I believe, going way back here!
If you need any help let us know.
Tobs
What parts are excluded Toby? Everything?
So £1000 just for fitting, seeing I supply engine and all extra parts?
Cheers
do you know all the other parts you need lol...as its quite alot, and it isnt cheap!
Good luck anyway mate...
Yeah that's just for the labour, it's not as easy as just removing the old one and installing the new one the loom has to be re-wired as it's made for naturally aspirated engines and not turbo engines. Some may be more, some may be less but we have a lot of expereince in this area. We can import used 4efte's from Japan for circa £550.00 as well, that will be a basic engine though you will still need the starter, pump, ignitor etc. Some also prefer to replace the shafts/hubs and brakes as they 4efe ones are smaller but some don't so completely up to you.
If you wanted to replicate the exact setup I would say around £2150.00 all in fitted and supplied. If you left shafts/hubs/brakes then you could knock a good £400.00 off this.
Hope that helps
T
Hope that helps
T
dont do the conversion,just buy one mate
Yeah that's it really, in the old days when Starlets were a lot more expensive then it was worth while but seeing as you can get a shabby GT these days for £1500.00 it's almost not worth it. The one great thing is that you can create a sleeper, the GT/Glanza are quite aggressive to look at with the skirts, spoiler, scoop etc where as the UK/Euro models are milder so you really can shock a few people!
Brake wise on the back drums are fine, the bias is minimal and drums are better for handling. Disks are really for aesthetics the performance is minimal. Obviously we are bringing out uprated rear brakes and calipers but these are tuned more towards to the high HP and track Starlets out there.
T
