Quad Lights Conversion on GT guide *
chinaone
Ok I posted up once before, but the thread has been lost on the old forum.
Heres the Tutorial again.
Unscrew the grill and bumper
Take off the crash bar, easier to work with.
Unscrew the lamp off the brakects.
Cut out all the RED area, inorder for the quads to fit, as they are much more bigger than the square lamps.
I use drill and hack saw, easier with air saw or some sort.
The brackets holding the lamps needs to be cut as pictured, but you can always get the brackets for the quads, save you cutting and holds better. as mines not that steady.
After moding the brackets and fitted.
Made my own brackets holding on the lamps, as i only have one at the top, you better to have one at top and one at bottom.
Now drill as the pic shows, so you can screw the lamp in place.
Testing with the grill in:
Wiring the bulbs as so
Here is a Wiring diagram i made:
As its a conversion, you cannot have all beams to come on at the same time, only side lights can be on all times with either main or hi. Cannot have main and hi on together.
After all fitted
Extra info:
High beam - HB4 / 9006
Main beam - HB3 / 9005
you may need to mod new bulbs, as the wings on the bulbs are bigger.
as what i've done to my HID bulbs on the pic.
The left bulb has been cut on the wings, as the right one has big wings on them.
I done alot of research before i done this conversion. Alot of help from members on TGTT, so credit to them all - OllyGTIR, Starlet_GTTurbo_Bristol, rameshsingh13, ppl who i forgot to mention, thank you!
Any problems give me a PM
All from me now, hope that helps, have fun:)
