x2.
priming the turbo and instructions::very important please read:::, fundimentaly important to any new hybrid turbo customers Options Track this topic Email this topic Print this topic Download this topic Subscribe to this forum Display Modes Switch to: Outline Standard Switch to: Linear+
Enzo
View Member Profile Add as Friend Send Message Find Member's Topics Find Member's Posts Jun 11 2008, 02:14 PM Post #1
cheesin since '90
Group: Admin
From: somewhere up in the hills plotting my revenge!
to any of you that have purchased a turbo you must take steps to prime the turbo before operating,
i canot stress how important this is as this is the main cause of turbo failure of new turbos due to the seals failing
priming basicaly involves making sure the turbo is lubed up with oil and oil pressure is up to normal peramiters.
to start with obviusly change the old engine oil
ad a wee bit of new oil to the inlet ala pic below
then take the kinglead off distributer cap so nonoe of the other leads get a spark (the one that goes into the middle in the pic)
and cranck the engine over until the oilpressure light goes off on the dash (aprox 30 seconds)
et voila you have now primed the turbo,
Start engine and make it idle for a couple of minutes. Check for any oil or any air leakage. Stop engine immediately if any weird sounds are heard.
on a side note, the turbo should not need running in but if you have any mechanical sympathy its a good idea not to go hammer and tongs with the boost straight away.
hopefully that made some sense,
if any of you peeps are stuck or have any questions dont hesitate to ask
these are the instruction enzo (tong turbo) sent me wen i brought his hybrid. pics didnt work. sorry
