Any Ideas?
Brendanlez
I have a 4-AGZE Corolla aswell, i went to take it to the house last night to do a bit of work to it, but its not running.
When I parked it up it was running, its a near finished project. It seems as if the car is not getting any petrol but when i pull the plugs out they are wet.
I checked the fuses and nothing seems to be blown!!!
Any ideas??? its starting to really fuck with my emotions:homer::mad:
Japsport85
check this 1st ^^
bit of a long shot, or silly suggestion :confused:
similar thing happened to a customers car, parked it up fine one nite, was running ok, next morning did not fire at all.
pulled the plugs out and they were wet, BUT, it had rained heavy over nite and the seals on the fuel filler cap were faulty.
turned out it was injecting water.
is a possiblity??
wastegate
what mods do you have on your engine and which ecu do you use?
Because one friend of mine had tuned engine with stock ecu and had similar problem with you...
Brendanlez
Only seeing the replys to this now.
Yea its sparkin, got a drive from it...
Its a Racetech piggyback ecu running off the 7A-FE Gxi ecu
The plugs are wet and its petrol because I can light it with my lighter when i take them out and clean them.
Chris if you see this would you be able to do anything with it?
