CR Developments UK - Brakes
Status
Not open for further replies.
Iain@CRD
In CR Developments UK Brake Section we cover everything from Brake Discs, Pads, Braided Lines and Full Brake Kits. We cater for the Toyota Starlet EP82/EP91 but we have them available for almost every manufacturer.
_________________________________________________________________
EBC Grooved Discs - EP82/EP91 (Front pair only)
Description -
  • Dimpled and grooved
  • Wide aperture grooves
  • Special disc alloys UNIQUE to EBC
  • Dimple hole construction
  • Balanced geometry
  • Zinc anodised coating
EBC Turbo Groove Discs, have a wider slot which actually draws cool air across the pad surface keeping pads and rotors cooler. Turbo Groove Discs also expel dust, dirt and hot gases better than fine slots which eventually fill with rust and scale and become ineffective in our opinion. EBC discs use blind drilled holes to break down surface gases when braking from speed but do not weaken the rotor cross section as can happen with through drilling, thereby lessening the chance of rotors cracking over time and heavy use.
Price - £135.00
Green Stuff Pads - EP82/EP91 (Front only)
Description -
• Fast Street use
• Brakes well from cold
• Effective up to 600°C
• Lower dust formula
• High friction formula
• Low disc abrasion
• MAX POWER Mega test winner
• AutoTrade awards winner
• UNDERCAR Digest top 10 awards winner
• For compact cars/hatches up to 200hp
• Not recommended for track use
Greenstuff is designed for spirited fast-street driving with better brake effect at loads and speed. Greenstuff has a high initial brake effect and gives drivers confidence from the first application of the brake pedal.
Greenstuff is the ideal choice for a premium replacement pad in performance street use and will stop your car more efficiently and effectively than standard OEM pads. They have been proven to stop a saloon car 9 meters quicker than OEM pads from 160kph.
They emit less dust than OEM pads and feature the EBC Brake-In™ coating which conditions the rotor surface and accelerates pad bed-in.
Price - £62.00
Yellow Stuff Pads - EP82/EP91 (Front only)
Description -
• Extreme street and racing use
• Effective to 900°C
• Very low disc abrasion
• Recommended for fast street, track days and full race use
Although a full race material and capable of high temperature use with very good wear life, this new formulation sets a new trend in race type brake pad compounds that can be used on the road. For road use check the availability for you vehicle in the Yellowstuff R formula.
The “bite” from cold is superb which is uncommon with race materials (normally requiring warm-up) and makes this a pad which can be safely used on both street and track. This new formulation has been used by numerous championship race and rally drivers and is truly a milestone in brake pad material development. Nominal friction coefficient 0.5 with zero rotor damage and the dust is the same or perhaps slightly more than many original pads; this is NOT a low dust pad.
Price - £75.00
EBC Ultimax Replacement Standard Brake Pads
Description -
EBC Ultimax Replacement Pads are a high friction pad designed for general replacement use on cars, vans and 4x4s.
Using shimmed, chamfered and slotted technology and incorporating EBC Brakes unique BRAKE-IN coating for super quick pad bed-in.
EBC Ultmax Brake Pads are black coded and manufactured from a high friction premium quality friction material approved to ECE R90 brake safety regulations and as such are an exact equivalent to original equipment pads fitted to your vehicle from the factory.
When you buy EBC R90 replacement pads you are getting an exact equivalent to an original equipment pad for far less money. Don’t let the lower price point cloud your view of this superb quality product, these pads will stop your vehicle as fast as any original equipment pad and faster than most aftermarket pads. One brilliant feature of EBC R90 pads is their ability to completely eliminate brake judder and these pads will actually COMPENSATE for mild brake judder after 300-400 miles of use. Nominal friction co-efficient 0.46 with minimal rotor damage and similar dust to original parts.
Front Price - £20.00
Rear Price - £22.00
HEL Performance Brake Lines
Description -
When you use HEL Brake Lines, you will have premium braided brake lines which are the essential choice for high performance, racing, custom cars and motorcycles.
  • Braided brake hoses made with premium grade stainless steel braided hose and fittings.
  • Eliminate that ‘spongy’ feeling - Giving you sharper and more responsive braking.
  • Coated in a wipe-clean PVC cover with a choice of 18 colours.
  • FMVSS-106, ADR, LTSA, DOT and TUV approved.
  • In-house manufacturing - care and attention put into each individual brake line.
These are braided brake lines you can 100% trust in any type of vehicle. Don’t risk using OEM brake lines which can corrode and wear out over time – putting your own safety at risk.
HEL stainless steel braided brake lines will give you sharper, more solid and more responsive braking at any speed or road condition.
They are available in the following colours:
Price - £55
K-Sport 6 Piston Big Brake Kit
Description -
The kits are comprehensive and include everything you need to fit the kit bar tools and fluid.
• Pair of lightweight calipers
• Pair of race specification heavy duty brake rotors
• Pair of lightweight CNC machined aluminum bells
• Pair of steel caliper brackets
• Set of Ksport brake pads
• Pair of braided brake lines with banjo bolts and fixings
• Full fitting kit
Available in 286mm and 304mm. (286mm for 15" wheels).
Price - £885
KIT DOES NOT INCLUDE PADS.
Mintex 1144 Brake Pads
Description -
4x Mintex fast road pads. One of the best available.
Price - £75.00
Mintex 1155 Brake Pads
Description -
4x Mintex track pads. One of the best available.
Price - £105.00
Status
