C
CaL
Guest
here is the info needed for a hks actiator to be fitted....btw make sure you buy the right actuator as early cars pre 92 were hole type and later 92 cars had a pin type actuator.... good luck!
http://www.tercelreference.com/articles/hks_actuator_installation/hks_actuator_installation.html
**EDIT :
After carrying out the fitting of a HKS actucator I can offer a little advice on the above information. The only way to set the level of boost is trial and error. The measurements in the tutorial above will not reflect everyones setup accurately.
My advice is to set it the same length as your current actuator and increase the tension after each test run using your boost gauge to determine the boost level.
Such is the way with 'cut and paste' information Cal here hasn't the experience to offer firsthand information in this case.
Kind regards,
**EDIT :
Kind regards,
