right,
fit the buckets, and the shims
u need to grease up, loads and loads of grease the cam lobes and where the cams sit in the head.
then rotate the cams and watch the buckets being pushed down.
and this is the rule,
when valve number 1 is pushed all the way down, you check the gap on valve 8
when 2 is down you check valve 7 and so fourth.
if any of the gaps are out, u need to remove the shim, measure the shim and either + or - the ammount you need to get the shim back in tolerance, and then either buy direct from toyota, or some engine specialists can help, or if u need to take some away a machinist can help.
its a little time consuming, and shouldnt be attempted if you dont quite understand it all
