Hi all
Due to the amount of threads on the hybrid turbo, ive decided to start the hybrid king thread, as youll see the first part is actually written by Red_hot, which i hope he doenst mind me copying and pasting.
This is not a thread for arguments on which is best. Instead i would like people to post up rolling road graphs, to show some concrete results.
Speedvision Hybrid CT9:
1. Brand new units casted from scratch-new compressor housing made with enlarged trumpet to suit compressor wheel, new turbine housing.
2. 12 bladed gt spec compressor wheel.
3. 9 bladed 10 degree cut back turbine wheel
4. brand new impeller shaft
5 brand new bearings and seals
6 brand new thrust bearing
7 upgraded adjustable actuator made from the hks model for stable boost
8 enlarged waste gate with bigger flap to suit , also for stable boost
9.fully balanced to oem specs.
1.2 bar of boost.
3-6 mths warranty.
395 gbp delivered anywhere in the world with usps 7-10 day priority shipping.
Available from www.speedvisioncps.com
Note: There have been problems with these turbos, i belive they sam is still trying to find out the problems with the turbos.
Tongs-turbo's hybrid CT9:
GT-spec ct-9 hybrid for the turbo ep market. (3rd revision)
£410 inc carriage
3 months limited warranty
Enlarged Compressor Inlet Trumpet to a massive 55mm
Compressor Wheel (Garrett GT type) 39.6mm
Turbine Wheel CT-9 Standard
Turbine Housing CT-9 Standard
Bored out waste gate port to 28mm
New waste gate flap 32mm
Fully Balanced
New Journal Bearing
270 degree(standard)thrust bearing
1.2bar of boost
Available from http://www.ukstarletclub.com/forums/index.php?showtopic=6211
TONG TURBO RESULT
Here is a power graph of the TONG Turbo GT spec (taken from ukstarletclub)
Michaels Tong turbo G spec hybrid at 1 bar
unichip fitted and mapped by Paul Hills @ Engine Advantages in Witham.
Car produced just under 214BHP @ the flywheel and 196lb/ft torque running 1BAR
SPEC
Small breather Filter
Magnecor Leads
Irridium plugs
g spec CT9 Hybrid
Dastek Unichip
WEPR FMIC
WEPR Full system
Walbro Fuel pump
S/S Manifold
HKS actuator
Blitz dual solenoid boost controller
Air con removed
Filter off turbo
TRD quickshift
Exeedy uprated clutch
SARD RRFPR
Autometer boost/oil pressure gauge
EBC brake pads
HKS SSQV
HKS FCD
Thermotec heatwrap
Quote from michael-
214BHP was at 1BAR, it did make 221BHP at 1.2BAR but my injectors need uprating so the tuner turned it back down to 1BAR.
Toy Tuning Uprated Hybrid CT9 Turbo
Fully re-conditioned including all seals and all new bearings.
Bead blasted
Modified larger Toy Tuning Compressor wheel
360 Degree thrust bearing
Waste gate ported
Cut back turbine blades
Supplied with brand new oil and water gaskets.
Recommended 1.1 bar of boost.
6 month limited warranty.
Work is done to your own turbo
Availble from www.toytuning.com
StarletGTturbo.co.uk Hybrid CT9:
Hybrid CT9 Turbo(Exchange)
1 year warranty
Capable of 1.3 Bar (210bhp)
On exchange bases
£650.00 + £12.00 Del.
Avaible from www.starletgtturbo.co.uk
To really see which is the best turbo, they should, of course be tested.
BUT, ideally, this should be done on one car on the same rolling road...
To got some sort of comparison, it would be good to get some sort of power-board running which includes people's full mod list to compare these different hybrid CT9
Some other rolling road graphs with the spec would greatly benefit anyone looking for a hybrid
1.2 bar of boost.
3-6 mths warranty.
£410 inc carriage
Fully Balanced
New Journal Bearing
1.2bar of boost
TONG TURBO RESULT
SPEC
Magnecor Leads
Irridium plugs
g spec CT9 Hybrid
Dastek Unichip
WEPR FMIC
WEPR Full system
Walbro Fuel pump
S/S Manifold
HKS actuator
Air con removed
Filter off turbo
TRD quickshift
SARD RRFPR
EBC brake pads
HKS SSQV
HKS FCD
Thermotec heatwrap
Quote from michael-
Bead blasted
Waste gate ported
1 year warranty
On exchange bases
