thermostat or heater matrix chap.
well before i changed the thermostat for under heating i'd never even had a wiff of hot air lol, not even warm! then i changed that and now an then i get 7secs of hot air!, maybe theres just a lil blockage in the matrix, is thur an easy way of flushing it out?
Remove both pipes to the heater matrix, flush with a hose.
Using d same diasmter hose (spare). plug in one side and blow, this would get rid of excess water. then add some Rad flush in it, leave 24hours, then flush with hose.
Then blow any excess water out. (do not get any in mouth). Plug one side of heater matrix hose back. using the spare hose add a funnel and add coolant in. once full quick swop the other hose back in. This would prevent air lock.
Thanks buddy, so does this involve removing the heater matrix? Cheers mate!
The pipes are against the bulkhead in the engine bay:
they lead into the top of the heater matrix which is in the cabin on the other side of the bulkhead.
- Remove both pipes.
- Attach hose to one pipe and flush.
- Then attach the hose to the other pipe and reverse flush.
- Once the water runs out clear you are done.
- Remember to bleed the air from the cooling system after you are finished.
No all done in the engine bay. No need to remove the dash (wish i use this method )
Cheers once again jay, thanks for the pic makes it alot clearer lol think i'll attempt it after work, so just attach a hosepipe to flush it? or another method, and when you bleed the system wahts easier way to do that to adoid getting air in system!?
haha thanks mate appreciate it
Yup, just push pressure through the system in order to unblock any channels obstructed by corrosion.
To bleed the system start the car with the rad cap off and let the air bubbles exit the cooling system. Just keep the level topped up and rebleed it after a days driving.
Work better with a jet wash . When flusing, do it on both sides IN and OUT
cheers, do they have them at like petrol garages to use? or lol...
Just use the home versions, the ones at the car wash's for example are too powerfull.
