Droplinks Info
The Low Down
There are two versions of droplink setup on the turbo models.
Between Dec 1989 and Dec 1991 (Phase 1 EP82) the turbos shared the same setup as the non turbo models. It consisted of a straight bar with four rubber bushes on each side held in place by two washers on each side.
In 1992 the turbo model got it's own L-shaped antiroll bar links (and it's own antiroll bar to suit). The design eliminated two of the rubber bushes on each side replacing them instead with a newly added joint on the drop link.
This offered improved handling and the setup remained right up until the EP's demise in 1999.
Phase 1 Droplinks
Parts required for full replacement (both sides):
Link rod X 2 = Part number 48819-10010 (approx £3.21 each plus VAT)
Rubber bush X 8 = Part number 48817-10020 (approx £4.76 each plus VAT
Metal washer X 4 = Part number 90948-02032 (approx £1.66 each plus VAT)
Bolt X 4 = Part number 94182-10800 (approx 1.25 each plus VAT)
Approximate UK retail price inc VAT = £65
Phase 2 Droplinks
Link rod X 2 = Part number 48820-10010 (approx £20.40 each plus VAT)
Rubber bush X 4 = Part number 48817-10020 (approx £4.76 each plus VAT
Bolt X 2 = Part number 94182-10800 (approx 1.25 each plus VAT)
Bolt X 2 = Part number 90179-10054 (approx 71p each plus VAT)
Approximate UK retail price in VAT = £82
Prices based on 2005 retail figures. They may have decreased/increased since then but any Toyota dealer can quote you on those part numbers.
Cheers,
