Removing bits around engine....Pic's inside...
Stulet-GTT
1st is Charcoal Filter,have jus done a search and read up but wanna make sure on couple of thing's...
2pipes curculed in red, i can jus join these up right?????
This way it will stop fuel fume's coming into car...
These two pipe's can i join these up or do i have to blank them seperate???
And is it ok to unplug this to remove it all???
2nd of All, can i remove this lot.....
Have red its somink to do with a/c, but i dont have it as all removed...
If i do remove it, can i just unplug this???
And join these pipes or block them seperate???
I have tryed to explain as best i can what i want to do, an tryed to get the pic's as best as i can..
stuarty1
you can unplug all that stuff just make sure it all bck in can i ask wat you movin it for ??
stuarty1
o i see fuck i hav no idea if you can just rip it all out will need ta ask some one else will do a serch on it ta c if i find eney thing will let you no
Matt Glanza
yea you can rip all that out.the outlets on the mani though blank them off individually as if you loop the may cause a high eratic idle like a vacum leak.with regards to the pipe going to the canister all i did was put a breather on the end of it as a temp.didnt have the bottom pipe on mine goin to the other box
Stulet-GTT
Well there it all is removed...
Gonna see if i can get the little pipes removed completly an maybe a little bolt put in hole..
Will look better once i have had the bay cleaned properly...
stuarty1
looks good did you do a we tortual ?? is is east or hard or is it just the case of rip it all out lol
smythy75
well if i need a chassis number i no were to get one! the last pic dude! id blank that over incase there is sum1 takes it for wrong reasons
