corofin12345
alot of people ask questions on here about how can you make you dumpvalve dump and flutter....? some people bung up the dumpvavle pipe that runs off the turbo so they can get the flutter noise and some just prefer the dump noise from the dumpvalve... i was messing with my car this morning an found a way of getting both noises with no need of buying extras to do so..
NOTE; this will only work with cars that have aftermarket dumpvalves (bov's) and cars that have the high/low switch bypassed..the flutter noise is not made by the dumpvalve, its made by the turbo itself
the way i used to get flutter is if i disconnected the vacuum hose off the dumpvalve and would have to replace if i wanted the dump noise.. the high/low turbo switch is the answer as most of us dont use this any more so its perfect for it.. as yee know you have to run a vacuum hose from inlet mani to dumpvale for it to run properly.. picture below shows what i did.. i ran a vacuum hose from dumpvalve to high/low switch and from high/low switch to inlet mani.. with the button off on the centre console you will get dump and with it pressed you will get flutter.. with it pressed all that is happening is that the vacuum source from the inlet mani is cut off by the high/low switch therefore the dumpvalve will not open causing flutter..
as you may of noticed i have relocated my dumpvalve to behind the front bumper.. this will work where ever your dumpvalve is placed..
