Results 1 to 4 of 4
    Jul 2010
    AUS
    82
    Default EP82/91 Ignitor wires
    Is the ignitor for EP82 and EP91 same?
    Here is a picture, seems like EP82 ignitor.
    Can anyone tell me what signal is each wire?? And where they connected to?
    Oct 2008
    canada
    92
    Reputation: 109 Members Garage: 1
    am not sure what car that ignitor in the picture is for but on my
    ep82 it use a (Toyota 201 ignitor : part # 's : 89621-12050 & or 131300-2010)
    the 201 ignitor works on a bunch of different car lexus,4runner,rav4,T100 Tacoma.. try parts number on ebay you will find them.
    as for the wires :
    1. IGF --goes to ecu
    2. IGT -- goes to ecu
    3.+B -- goes to Battery
    4. IG- -- goes to IG- check connector/ dia port under hood
    5. coil -- goes to ignition coil
    Note: double check/ trace them with a multimeter before you make any connections. as they might be numbered depending how you looking at the ignitor plug.
    Mar 2009
    Luton
    354
    according this ECU diagram, does number 3 black and red also connects to the coil pack. is that right?
    Paid Member weeJohn's Avatar
    Co. Antrim
    6,245
    Reputation: 3797 Members Garage: 2
    The ignitors are wired the same way, I have fitted a 91 coil to an 82 before. Only problem you will find is, there is a raised lip (you can see it in your pic on the coil itself, in between the line of wires 4 and 5) on the coil socket and its in a different place on the 2 coils. Just cut it off with a Stanley knife and you are away.
    243 bhp, 210 ft/lbs of torque, 4 wheels to put it through
