Gee
OK, I was guessing they are not, but others have told me they are?
However, the ZEP modified baffle is the stock pan which has been modified. So, have they baffled it or have they made adjustments to the existing baffle?
Info from RHD below.
1 question - It says to clean the baffle when received. Is this with any special chemicle at all?
There are not pictures of the inside...ZEP have told not to show them.
You are viewing a Brand New 'Modified Baffle Oil Pan' by the circuit and Starlet specialists, ZEP Racing.
The item was developed with ZEP's vast knowhow on the circuit and refined with test and error development on the track.
This unit is very important for when you are running your engine hard and pulling G forces above normal driving as it will keep the oil around your pickup so your engine will never be deprived of oil. It will help keep blowby gases down and comes highly recommended when if your oil pressure tends to drop when cornering.
As this item is the OEM oil pan which is modified/welded by ZEP, it is recommended to do a final cleaning on the inside of the unit after receiving it. *We have been requested to not show the inside of the unit (baffle part) by ZEP.
