Dave@TM-developments.com
Trader
First things first as a tribute to Monkfish
Make a brew
Now jack up the car on the proper points and support the vehicle
Remove caliper and pad carrier
Remove disc
Admire the new disc
Now thoroughly clean with brake cleaner(posh cleaner courtesy of Kev)
You will notice the calipers come with the hose adapter already fitted. DO NOT try to tighten this further, it is a tapered thread and should be like that
Remove 3 torx screws holding on backplate
Time for another
Carefully cut and reamove back plate, SHARP!
Thoroughly clean stub axle, the discs are a snug fit and these do need to be clean
Fit new disc
Fit new bracket with loctite provided
Fit new pads to calipers, such a simple neat idea
Bolt caliper to bracket with loctite
As we only did a dry fit as the car is off the road you will need to fit the hoses and bleed the system. Bleed using both TOP bleed nipples
Refit wheel stand back and admire the beauty
A job well done!!
Make a brew
Remove disc
Admire the new disc
Time for another
Fit new disc
A job well done!!
