You will need absolutely nothing.The only difference is a few sensors but just swap them from your old engine onto the Glanza engine.I know this for fact as i've done quite a few.Any one who says different is WRONG.
ok does the mk1 ep82's have a 2 pin ecu? glanzas have 3.
the glanza 4efte has a throttle position sensor which analogically and thats the main difference that must be taken care during the swap? am i wrong?
so the mk1 ecu can take care of this? or the existing harness? apologize if im wrong or have em confused.
ive just changed a ep91-ep82 engine and the TPS are the same, theyre both 3 pin, both have the same part numbers, only difference was one has a silver sticker and the other a purple. only the auto's have a variable TPS.
its a straight swap ....just use back your sensors and maybe intake manifold depending .........also some heads have a small coolant hole in them at the back while others dont----CHECK this, cause u could experience a leak if there is a mis-match
