is this one is the knock sensor :
E EH@B Member + Jan 1, 2009 #6 thnx dane for make more sure rep added i changed it because my cheak engine light come on when RPM over 2000 but still didint try the car
dantheman Member + Jan 1, 2009 #7 if your ganna change it make sure you dont over tighten it when doing the bolt up as it will not function properly.
E EH@B Member + Jan 2, 2009 #8 dantheman said: if your ganna change it make sure you dont over tighten it when doing the bolt up as it will not function properly. Click to expand... thnx dan for info rep added
