sx_turbo
COMMA DOT 5.1 racing brake fluid 1ltr
£7.67+vat
COMMA DOT4 brake fluid 1ltr
£3.81+vat
BLACK DIAMOND grooved discs
£111.08+vat
BLACK DIAMOND dimpled disc
£111.91+vat
BLACK DIAMOND grooved and dimpled discs
£124+vat
BLACK DIAMOND performance pads
An ultra low dust high friction, high temperature compound with a heat transfer layer next to the backing plate to transfer heat away from the disc and pad enabling operating temperatures of slightly over 520deg with no fade at all. Black Diamond predator pads complement the black diamond disc range perfectly or if you wish you can gain extra braking performance by using the black diamond predator pads on their own with standard discs.
£33.50+vat
FERODO RACING DS2500 series front pads
Ferodo’s DS2500 racing brake pads represent a new generation of friction material that’s low in compressibility, ensuring a firm pedal while providing great disc and pad life.
These pads were developed with characteristics that make them perfect for track days, including a consistent coefficient of friction (0.50) at any temperature, providing very predictable braking and great pedal modulation.
Combined with low wheel dusting and good noise characteristics, this product is the brake pad for the driver who needs the highest track-day braking performance.
£79.50+vat
ADL Blueprint HANDBRAKE CABLE LH 1992 ON-
£13.87+VAT
ADL Blueprint HANDBRAKE CABLE RH 1992 ON-
£13.87+VAT
ADL Blueprint FRONT brake cable pre 1992
£6.97+vat
ADL Blueprint FRONT brake cable 1992 on
£6.59+vat
ADL Blueprint standard front pads
£11.68+vat
ADL Blueprint standard rear pads
£21.19+vat
ADL Blueprint STANDARD FRONT DISCS PRE 1992
£56.27+VAT EACH
NIPPARTS standard front discs 1992 on -
£30.37+vat
ADL Blueprint standard rear discs with ABS
£47.28+VAT EACH
ADL Blueprint standard rear discs WITHOUT ABS
£33.83+VAT EACH
BRAKE ENGINEERING front brake discs 92 on-
£45.88 + vat for the pair
EBC GREEN STUFF pads
£42.42+vat
EBC YELLOW STUFFpads
£53.84+vat
£7.67+vat
£3.81+vat
£111.08+vat
£111.91+vat
£124+vat
£33.50+vat
£79.50+vat
£13.87+VAT
£13.87+VAT
£6.97+vat
£6.59+vat
£11.68+vat
£21.19+vat
£56.27+VAT EACH
£30.37+vat
£47.28+VAT EACH
£33.83+VAT EACH
£42.42+vat
£53.84+vat
