btw, glanza and GT TPS aren't working the same. Glanza one are reverse type (0 volt when full throttle)
I've shortened from ECU side.
and ...
and ...
you were right my friend. I owe quite few beers !!
thank you for insisting !
I asumed by mistake TPS was fine, but this is the prob !!
now timing is at 10 °BTDC when distributor is at middle !!!
I can hear a engine sound change when I bridge and unbridge (tried while engine at iddle)
Sheldon, sounds lik ea good idea !
Morpheus, maybe they were not adjusted properly
Texx, thanks for the link. I adjusted using an other trick. I moved the tps until I could hear an engine sound change. then I plugged timing light, and did check were was the contact point. it change for 10° to 20° so it is very easy to find out.
left a small gap to be sure it will read closed. job done
TGTT, definitly one of a freaking nice comunity !
