ChrisGT
I've signed up to the Aus Starlet club and on a couple of occassions I have read posts saying that a SAFC can and does remove fuel cut, so you do not need a FCD to accompany it. Why would they be able to do that and we not? Has any one actually tried just a SAFC & FPR and got it tuned?
Worth a discussion I think!
Some links:
http://www.austarletclub.com/forums/index.php?showtopic=9547&st=60&p=136444&#entry136444
http://www.austarletclub.com/forums/index.php?showtopic=9547&st=60&p=136444&#entry136444 * So if fuel cut can only be raised if you are using the SAFC to "pull fuel out" i.e. lean it out, that would be perfect for a FPR/SAFC combination. Setting the FPR high, then using the SAFC to trim.
http://www.austarletclub.com/forums/index.php?showtopic=9547&view=findpost&p=136460
Some links:
