exhaust manifolds.......disertation project
59bhp
hello all,
basically i need some information for my disertation and i was wondering if you lot could help. Its quite important so i knida need as much info as possible.
Basically if you have ever bought an exhaust manifold that has ended up cracking then could you please fill out the form below and post it up. Notice i havent put a field for naming who made it as im not interested in that bit and i dont wanna start a conflict lol
so anyways heres the template:
Manifold material:
date of purchase (doesnt have to be hugely accurate):
Length of time before failure (how long it lasted before cracking):
mileage on car it was installed on:
type of manifold (tod4, ct9, external wastegated etc)
if it was braced:
if so then where:
type of exhaust system (downpipe back):
approx max power of engine it was installed on and rpm this occured:
cheers people
WallaceGlanza
Manifold material: Stainless Steel
date of purchase (doesnt have to be hugely accurate): 10/04/07 ish
Length of time before failure (how long it lasted before cracking): a little over 4 months
mileage on car it was installed on: prob about 75-80k miles
type of manifold (tod4, ct9, external wastegated etc): CT9
if it was braced: Not the mani itself but the downpipe was
if so then where: Downpipe stock brace
type of exhaust system (downpipe back): Blitz decat with stock brace attached then 2.5" custom stainless steel straight through
approx max power of engine it was installed on and rpm this occured:190bhp, I don't rev the engine that hard and can't give an exact rpm of when the mani cracked
ChrisGT
Manifold material: Stainless steel (SUS 304)
01/03/08
Length of time before failure : 6months
68K-ish
CT9
if it was braced: Yes.
if so then where: Flange to flange.
type of exhaust system (downpipe back): Front exit exhaust (with bracket)
approx max power of engine it was installed on and rpm this occured: Was used for awhile at stock boost, then 1.1Bar, then stock boost again. Cracked over summer whilst running 10Psi. Don't know exactly when it cracked, sorry.
Dane_Bristol
Manifold material: Stainless Steel (SUS304)
Date of purchase (doesnt have to be hugely accurate): 01/01/2007
Length of time before failure (how long it lasted before cracking): 3 Months
mileage on car it was installed on: 85 000 ish
Type of manifold (tod4, ct9, external wastegated etc)
if it was braced: Not braced CT9
if so then where: N/A
type of exhaust system (downpipe back): Custom made decat back.
Approx max power of engine it was installed on and rpm this occured: 140bhp approx. Came down to thin runners and just randomly cracked.
wainy
Manifold material: stainless steel
date of purchase (doesnt have to be hugely accurate): july 2008
Length of time before failure (how long it lasted before cracking): 1500miles
mileage on car it was installed on: 60000miles
type of manifold (tod4, ct9, external wastegated etc) td04
if it was braced: yes
if so then where: flange to flange then flange to external wastegate
type of exhaust system (downpipe back): decat back
approx max power of engine it was installed on and rpm this occured: 266bhp-approx 3500revs at 70mph on motoway
I'll give you a different one.
Manifold material: Cast
date of purchase (doesnt have to be hugely accurate): Dec 1995
Length of time before failure (how long it lasted before cracking): Still going
mileage on car it was installed on: 130,000 kms
type of manifold (tod4, ct9, external wastegated etc) : Stock CT9
if so then where: Downpipe to block
type of exhaust system (downpipe back): Stock
approx max power of engine it was installed on and rpm this occured: Currently somewhere above 133bhp.
WallaceGlanza
Where can I get one of those?! It sounds awesome!!111!!:eek::beer:
WallaceGlanza
Kick me while I'm down why don't you! I thought you had found the holy grail of exhaust mani's.:p
It suits the application its designed for though, its when silly people start "tuning" that these things fail and are replaced with even worse items.:rolleyes: (Yup been there done that)
Exactly. It suits the manufacturers specification perfectly.
I've seen some mk1 manifolds still running uncracked and that makes them an easy 16 years in service.
Only once you head beyond the manufacturers spec they become an issue.
59bhp
well this is what im going to try and remedy, using real gas flow and stress and strain analysis so i can at least have the information should i want to manufacture an unbreakable manifold.
Not one type of aftermarket manifold i have seen has had 100% success rate and using decent engineering methods and software im going to try and design a tubular manifold that not only flows as good as any out there but will not fail.
hell if i manage it i might even publish it lol
Harvey
Yeah they are pretty durable units! My stock manifold only recently cracked, maybe 5-8k miles ago before i welded it back up. And my car is a 1994 model and done about 135k miles now!
Nick@TD.co.uk
Registered Trader <a href="http://www.TuningD
Interesting thread Mike, will be good to see how everyone has found there manifold's, i've seen many Manifold's crack so will be good to see you create one that should stand up to the test of time alot better, I'll give any help i can mate as will be cool to see you getting involved with this.
~Nick @ Tuning Developments
59bhp
cheers buddy,
bump ive witnessed first hand some mild steel ones that failed so anyone have any info please come forward
dave-izzle
Manifold material: stainless steel SUS304
date of purchase (doesnt have to be hugely accurate): june 2008
Length of time before failure (how long it lasted before cracking): about 3 months
mileage on car it was installed on: 96,000miles
type of manifold (tod4, ct9, external wastegated etc) CT9
type of exhaust system (downpipe back): Decat to full system
approx max power of engine it was installed on and rpm this occured: 175bhp, over a small length of time really
nexia201
date of purchase (doesnt have to be hugely accurate): august 2008
Length of time before failure (how long it lasted before cracking): about 1month
mileage on car it was installed on: ???????
type of exhaust system (downpipe back): Decat only
approx max power of engine it was installed on and rpm this occured: 135 to 150bhp
