Iain@CRD
Toyota Starlet Stainless Steel Tubular Manifold
Fits Toyota Starlet Turbo 4E-FTE 1989 onwards
This high quality stainless steel tubular manifold will replace the original cast iron unit, CAD designed for optimum gasflow it allows exhaust gasses to exit the turbo faster, increasing performance, speeding up spool time, reducing turbo lag and improving throttle response.
Features:
Fits Toyota Starlet Turbo 4E-FTE 1989 onwards.
Price - £215.00
Toyota Starlet Turbo Decat Pipe
Removing the original, restrictive cat converter and replacing it with this performance downpipe will improve exhaust gasflow and allow your engine to breathe much easier.
This pipe reduces back pressure and allows your turbo to spool up faster, reducing turbo lag and improving throttle response and approx 15BHP instantly gained.
Features:
Price - £165.00
Toyota Starlet EP82 CAT Back Exhaust System
This exhaust is made to the highest standard and gives a very deep aggressive sound through a 4 1/2 Inch tailpipe.
Features:
Fits Toyota Starlet EP82.
Price - £330.00
Toyota Starlet EP91 CAT Back Exhaust System
Features:
Fits Toyota Starlet EP91.
Price - £330.00
Seven Row Oil Cooler and Relocation Kit
This high quality kits will allow you to relocate the factory oil filter for easy maintenance and quick access to your oil changes by making the oil filter more assessable which is ideal for track & drift days.
Enhances the look in the engine bay and it helps prolong the life of your oil and in turn your internal engine components by keeping the oil temperature down.
Standard oil coolers use a small devices sandwiched between the oil filter and engine block, these are taxing on the cooling system even under normal driving conditions.
Features:
Price - £170.00
Toyota Starlet EP82 EP91 Front Mount Intercooler Kit
Front mount intercooler kits are an excellent way of safely increasing BHP by reducing the engine's inlet temperatures a denser air charge will enter the engine.
This will make more power at the same boost level.
All intercooler kits are designed to give maximum cooling capacity while allowing for minimal pressure drops.
Features:
Each kit is designed specifically for each model of car.
Price - £290.00
Toyota Starlet High Flow Race Radiator
Fits Toyota Starlet Turbo 1.3L 12v EP82 / EP91 1989-1999
This aluminium tripple core design racing radiator will achieve 40% more cooling capability than a standard radiator.
Features:
Price - £150.00
Adjustable Fuel Pressure Regulator
Fits all fuel injected cars
Height from bottom of unit to top is 90mm.
CNC machined aluminium.
Kit comes complete with everything shown in picture.
Price - £65.00
Universal Oil Catch Tank
For modified cars, reduces oil vapour from the breathers.
65mm x 80mm x 180mm.
10mm inlet and outlet pipes.
Features:
**Currently only Available in Silver and Red**
Price - £57.00
Universal Electric Radiator Cooling Fan
These slim, reversible electric fans are perfect for additional aftermarket cooling
These slim, reversible electric fans are perfect for additional aftermarket cooling or replacement of factory radiator fans.
They can be used in a wide variety of other applications, including air conditioning condenser cooling, mounting on an intercooler to prevent heat soak during track / drift racing events or cooling the radiator in a water-to-air intercooler setup.
The blades on our fans are easily reversible, not just the motor, this means you get the superior flow of a curved-blade design with the versatility of a push / pull reversible fan.
Our fans are only 2.5 Inch at the deepest point, making them ideal for installations in cramped areas.
These fans include the mounting kit.
Features
Price: 10" - £55.00
Toyota Starlet Turbo EP82/91 Hawk Front Carbon Brake Pads
HPS - 'High Performance Street'
Superior stopping power
HPS - High Performance Street disc brake pads are world renowned for increasing stopping power on your street legal vehicle. Increasing the performance of your vehicles braking system is easy when you choose Hawk Performance’s HPS braking compound. This unique Ferro-Carbon formula was developed for street performance using the safety and quality of Aerospace and Motorsports severe-duty friction technology.
The High Performance Street compound offers a higher coefficient of friction over stock brake pads and can provide you 20-40% more stopping power and higher resistance to brake fade than most standard replacement pads. Less fade means you’ll have a highly durable brake pad with less brake dust..
HPS Ferro-Compound Features:
* Increased stopping power
* High friction/torque hot or cold
* Gentle on rotors
* Extended pad life
* Low dust
* Virtually noise-free
You are buying a set of FRONT Brake pads.
Price - £57.00
Features:
- High quality grade T304 stainless steel manifold.
- 3mm thick, mandrel bent polished stainless steel.
- Huge weight reduction.
- Significantly increase torque and horse power over the entire RPM range.
- Increases throttle response and exhaust flow.
- Direct replacement.
- Gaskets included.
- Will need support brackets if fitted with a decat pipe.
Price - £215.00
Features:
- Made from high quality T304 stainless steel.
- Fully TIG welded.
- Mandrel bent, CNC machined flanges, 2.7 mm thick pipes.
- Downpipe pipe is 2 1/2 Inch (63mm) bore right through.
- Lambda boss fitted to accept OE Lambda probe (O2 sensor).
- Direct bolt-on fitment, no modifications required.
Price - £165.00
Features:
- Made from mandrel bent T304 stainless teel.
- 2.25 Inch downpipe, 3 Inch mid section with 4 1/2 Inch tailpipe.
- Will improve throttle response and increase power by up to 15BHP.
- Mirror polished all the way through, not just the tailpipe!
- Gaskets and bolts included.
Price - £330.00
Features:
- 2.25 inch throughout with 4 1/2 Inch tailpipe.
Price - £330.00
Features:
- Sandwich plate
- Comes with oil filter adapters for most applications.
- Takes off’s for oil gauges.
- Give engine higher oil capacity.
- High pressure stainless steel braided hoses.
- Essential piece of kit for track, drag or drift days,
- Keeps oil temps down.
- Oil Filter relocation for easy access, a must for a hard to reach oil filter.
- Comes with a seven-row cooler.
- We recommend these kits are fitted by a professional mechanic to ensure the correct fittment.
Price - £170.00
Features:
- Bar and plate intercooler, core size 580 x 270 x 70mm.
- High flowing hand made end tanks.
- Polished aluminium pipework
- All necessary clamps, fittings and silicone hoses.
- Maximum cooling capacity while allowing for minimal pressure drops.
- 1050cfm @ 0.5 psi drop.
- Capable of handling up to 400BHP.
- Fits Toyota Glanza / StarletTurbo EP82 EP91.
Price - £290.00
Features:
- Massive 40mm thick for maximum cooling efficiency.
- Aluminium radiators are more efficient than standard radiators and will help keep engine temperatures.
- Ideal for track use or modified cars.
- Greater cooling capacity than any other radiator on the market.
- Full alloy radiator with custom polished top and bottom tanks designed for a perfect fit.
- Perfect for performance upgrades.
- Overall size 665mm x 410mm x 55mm.
- Core size 635mm x 330mm x 40mm.
Price - £150.00
Price - £65.00
Features:
- Made from 100% aluminium.
- Comes with everything shown in the picture.
- Catch the oil and moisture in the blow-by gas that causes carbon and sludge build-up in the intake system and the engine, especially good for turbo cars.
- Keeps the engine clean even under hard driving conditions.
- Excellent item for engine bay dress up.
- Mirror polished aluminium.
- Fit's all model of car's.
Price - £57.00
Features
- Fan is constructed from durable lightweight composite
- Slim design allows more clearance with engine components. (e.g. turbochargers, intercoolers)
- Durable and powerful motor for long life and performance.
- Provides exceptional cooling and up to 1720 CFM each.
- 2.5 Inch thick at the motor.
- Includes: lightweight composite racing radiator fans and brackets.
- No instructions included.
- Professional installation is highly recommended.
- Push/pull design.
Price: 10" - £55.00
* Gentle on rotors
* Extended pad life
* Low dust
Price - £57.00
